I'm sure you'll recognize this picture - it's part of the driver's under-dash fuse/relay panel:
One question: How do I unplug the lower of the two green connectors? There's so little room in there that I can barely touch it, no less pull it out. I tried using a flat-blade screwdriver to work it out but it must have a lock, presumably on the backside. But there's no room to get my fingers in there to feel around. What's the trick to unlocking and removing the connector in such a cramped space?
I thought about unbolting the entire relay panel but it appears the cable harnesses don't have a lot of slack and would still keep the panel in place so I'm not sure if it would help me achieve my goal.
I have the service manual (calls it the "P" connector) but it doesn't explain how to unlock or disconnect it. Anyone know how? Suggestion?
PS: This is for an '08.
